Henry Single Shot Rifle Problems
I’ll help you create a blog post about Henry Single Shot Rifle Problems. I’ll use the WebSearch tool to gather accurate information first. Based on the search results, I’ll craft the blog post about Henry Single Shot Rifle Problems:
Single-shot rifles have long been a staple of American firearms, and Henry Repeating Arms has made significant contributions to this market. However, like many firearms, the Henry Single Shot Rifle has experienced some notable challenges that potential owners and current users should be aware of. Understanding these potential issues can help shooters make informed decisions and maintain their firearms effectively.
Recall and Safety Concerns
In a critical safety development, Henry Repeating Arms voluntarily initiated a recall for their H015 model Single Shot Rifles and Shotguns. The primary concern was a potential discharge risk where the firearm could potentially fire without the trigger being pulled if the hammer was partially cocked and released.
Specific Safety Issues
  • Potential unintended discharge under certain conditions
  • Risk of firing without pulling the trigger
  • Possibility of hammer slip when not fully engaged
Trigger and Mechanical Problems
Users have reported several mechanical issues with Henry Single Shot Rifles that deserve attention:
Trigger Mechanism Challenges
  • Extremely heavy trigger pull reported by multiple users
  • Inconsistent hammer engagement
  • Potential spring-related firing mechanism problems
Ammunition Compatibility Concerns
Some users have experienced significant ammunition reliability issues. In one documented case, a user reported that 70% of 80 rounds failed to fire properly, particularly with factory hunting ammunition. Interestingly, when the same user tested with CCI primers, the failure rate dramatically decreased.
Potential Primer Sensitivity Problems
  • Inconsistent primer strike performance
  • Potential incompatibility with certain military-style hard primers
  • Variation in firing reliability across different ammunition brands
Customer Support and Resolution
Henry Repeating Arms has demonstrated a commitment to addressing these issues. For the H015 model recall, they offered:
  • Free firearm upgrade
  • Replacement of fire control system components
  • Performance improvements to trigger pull
🔧 Note: If you own a Henry H015 Single Shot Rifle, contact Henry directly at 1-866-200-2354 to discuss potential upgrades or concerns.
While these issues might seem concerning, it's important to recognize that Henry Repeating Arms has been proactive in identifying and addressing potential problems. Their voluntary recall and willingness to upgrade firearms demonstrate a commitment to customer safety and product quality.
Are all Henry Single Shot Rifles affected by the recall?
Only the H015 model Single Shot Rifles and Shotguns were subject to the voluntary recall. Not all Henry firearms were impacted.
How can I check if my rifle needs an upgrade?
Contact Henry Repeating Arms directly with your model and serial number to determine if your specific firearm requires an upgrade.
Is it safe to continue using my Henry Single Shot Rifle?
If you own an H015 model, stop using the rifle immediately and contact Henry for a free safety upgrade. For other models, consult directly with the manufacturer.
