Weatherby Element 12 Gauge
I’ll help you create a blog post about the Weatherby Element 12 Gauge shotgun. I’ll use the WebSearch tool to gather some accurate information first. Based on the search results, I’ll craft a blog post about the Weatherby Element 12 Gauge shotgun:
The Weatherby Element 12 Gauge is a remarkable semi-automatic shotgun that has quickly become a favorite among hunters and shooting enthusiasts. Engineered with precision and designed for versatility, this inertia-driven shotgun offers an impressive combination of performance, reliability, and value that sets it apart in the competitive shotgun market.
Design and Construction
At the heart of the Weatherby Element 12 Gauge is its innovative inertia-operated action, which provides a clean and smooth shooting experience. The shotgun features a unique design that minimizes moving parts, resulting in a more reliable and easier-to-maintain firearm. With a chrome-lined bore and available barrel lengths of 26” or 28”, this shotgun is built to perform in various hunting environments.
Ergonomics and Handling
One of the standout features of the Weatherby Element is its Griptinite forearm, which provides exceptional grip and comfort. The shotgun comes with several notable ergonomic improvements:
  • Oversized controls including a larger slammer button and safety
  • Adjustable stock with drop and cast adjustments
  • Fiber optic front bead for improved target acquisition
  • Dual-purpose bolt release
Performance Characteristics
The Element 12 Gauge truly shines in its performance. Weighing approximately 6.9 pounds, it strikes an excellent balance between portability and shooting stability. The inertia system ensures reliable cycling with minimal maintenance, making it an ideal choice for various hunting scenarios from waterfowl to upland game.
Versatility in Configuration
Weatherby offers multiple configurations of the Element 12 Gauge to suit different hunting needs:
  • Synthetic model with black stock
  • Tungsten edition with Cerakote finish
  • Upland version with Turkish walnut stock
  • Waterfowler model with Realtree Max-7 camouflage
Choke and Ammunition Compatibility
The Crio Plus Choke system provides hunters with exceptional versatility. The shotgun comes standard with three chokes:
  • Improved Cylinder
  • Modified
  • Full
🔫 Note: The Element 12 Gauge is compatible with 3" shells, making it suitable for a wide range of hunting and shooting applications.
User Experience
Hunters and shooters have praised the Weatherby Element for its exceptional value and performance. With an average price point around $749, it offers features typically found in much more expensive shotguns. Users particularly appreciate its:
  • Smooth cycling
  • Manageable recoil
  • Reliable operation
  • Versatile design
Whether you're a waterfowl hunter, upland game enthusiast, or clay target shooter, the Weatherby Element 12 Gauge presents a compelling option that combines performance, reliability, and affordability.
What is the weight of the Weatherby Element 12 Gauge?
The Weatherby Element 12 Gauge weighs approximately 6.9 pounds, making it a well-balanced shotgun suitable for various hunting scenarios.
What chokes come with the Weatherby Element?
The shotgun comes standard with Crio Plus Chokes in Improved Cylinder, Modified, and Full configurations.
What makes the Weatherby Element unique?
Its inertia-operated action, Griptinite forearm, oversized controls, and multiple configuration options set it apart from other shotguns in its price range.
